How can I open a WAV file in LabVIEW 7?
I need to make a program that opens a WAV file and converts it into amplitudes values and saves the in a .txt file. But how can I make LabVIEW 7 open up a WAV file? It's probably easy, but I didn't come up with anything up to now!
Thanks in advance!
Message 1 of 11
(4,510 Views)
try this
regards
timo
Message 2 of 11
(4,478 Views)
sorry, didn't work
the .txt was created, but it was blank
thanks!
Message 3 of 11
(4,441 Views)
well, i use LV 7.1 & WinXP and creates a txt file with values
try to use the VI with different wavs
play around with the parameters
regards
timo
Message 4 of 11
(4,436 Views)
Ok, I'll try that!
Thanks!
Message 5 of 11
(4,433 Views)
Hi Timo,
I'm using LabVIEW 7.1.1 and WinXP, for me also, the text file is created but empty...
Is it working with files in C\WINDOWS\Media on your computer ??
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 6 of 11
(4,424 Views)
I attached the tada files
Message 7 of 11
(4,419 Views)
Thanks Timo,
It now works Smiley Happy.. I still dont know why it didn't work the first time...
Epictetus
Antoine Chalons
Message 8 of 11
(4,415 Views)
It worked here as well, thanks!
I still have a problem, though... My .WAV file is 30 seconds long, and I only want the first 3 sec of data to be written in the text file! Can this be done? I made the program stop after n number of iterations but it didn't work, the file was still acquiring all the data!!
Message 9 of 11
(4,394 Views)
my suggestion:
after reading the wav file => write the information in an array => resize the array => write to file
regards
timo
Message 10 of 11
(4,382 Views)
