How can I open excel application minimized
I would like to open excel minimized so it can be closed by the operator if the program does not clean it up properly. How can I open the program minimized.
 I'm thinking it has to do with the WindowState property, but don't have any documentation about the activex properties. Would anyone know?
(4,850 Views)
Like this:
As for the documentation, when installing Excel select "Advanced" or "Customize" and then select "Visual Basic Help". That installs the Help file for the automation functions. You can also get the documentation on MSDN.
Message Edited by smercurio_fc on 08-29-2008 09:43 AM
(4,847 Views)
I think I just answered my own question. The diagram that you have is close, but requires the WindowState as an additional parameter. I didn't reallize that it was already enumerated. I thought I was going to have to guess the integer value like I do for the save as when I try to select a format.
(4,841 Views)
Actually I just realized that I misread your post in terms of minimization vs visibility. Smiley Very Happy
(4,839 Views)
I figured how to open a workbook, but how can I open a worksheet by name. I'm used to opening it in CVI.
(4,833 Views)
It's no different. The ActiveX functions are the same.
You may wish to peruse the "Excel board".
(4,828 Views)
