How can I open the "Pane Properties Dialog Box", without right-clicking on the scrollbar of the pane?
To open the "Pane Properties Dialog Box" the LabVIEW Help suggest following:
"Right-click in the scrollbar of a pane and select Properties from the shortcut menu to display this dialog box."
The Problem is that I would like to switch off the scrollbars, which once done, means I can't right-click on the scrollbar anymore !
There must be a different way to get to this Menu, too ?!
(2,975 Views)
Once the scrollbars are off, simply right-click on the splitter bar directly and select "right|left pane...properties" (or upper|lower pane ... properties for horizontal splitters). 🙂
(2,962 Views)
Ok this works if have a splitter bar added to the front panel!
But what if you haven't even a splitter bar to click on?
(2,947 Views)
Typically, you would hide the scrollbars only when running, and in this case there is no problem. I guess you should keep at least one of the scrollbars visible in edit mode.
Once both scrollbars are hidden, you can restore them using the "VI properties...windows appearance...customize" dialog. 🙂
(2,934 Views)
