How can I optimize Remote Panel VIs?
I have the Problem that the Connection to the Server to be disconnected if
After a while I get The Message if the Bandwith is to small in the Browser "The Server is disconnected " .in German "Die Verbindung zum Server wurde unterbrochen". How can I optimize mY VI for Remote Panel? I have tried with Waitfunktions? reduzing ammount of Data. sent?
(2,832 Views)
Here are a few other things to keep in mind. First, try to minimize the amount of UI processing that is required. This can slow down your connection immensely if you have a lot going on. Also, minimize the amount of advanced communication. Use property nodes or events sparingly - Each property node requires a roundtrip between the server and the client. Hopefully these considerations can help you out. Best of luck.
J.R. Allen
(2,832 Views)
