How can I pass unknown data types to a vi
I would like to create a vi that accepts two inputs, 1) being a ref to vi to call/run and 2) some data to pass to the called vi
I would like to be able to design a genric vi that will accept any data type including arrays, structures etc
I of course would then have to be able to get hold and use the data in the called vi.
Polymorphism springs to mind but I don't know what types of data I need so this is not possible.
Can anybody help ?
Cheers
Steve
(2,860 Views)
Variant!
See
Communications >>> ActiveX >>> TO Variant
and
Variant to data
Ben
(2,860 Views)
Hi Steve,
Thank you for contacting National Instruments.
Ben's suggestion is a great idea. I have attached an example program that illustrates how to use variants. The example does File I/O, but you can apply the same concept with the use of subVIs. In addition, the link below will take you to another post where one of my colleagues discusses how to build a polymorphic VI, in case that becomes an option for you.
http://exchange.ni.com/servlet/Redirect?id=11366374
I hope this helps!
Matthew C
(2,860 Views)
