How can I plot time in seconds?
Hi, I have a little problem in ploting a graph versus time (x-axis)... I noticed that the time scale is not right, where the time is neither measured in seconds nor milliseconds. But it was every 50 units equivilent to 4 seconds (approximately), and I didn't change anything in its properties. What could be the problem? And how can I solve it?
I have searched a lot in the forums, but I didn't find it in a clear discussion. Any help please?
Flifl, Labview2009-vista
Message 1 of 8
(10,002 Views)
If you are graphing a waveform data type, uncheck 'Ignore Timestamp'. Without the dt information, a graph has no idea what your sample rate is and defaults to a dt of 1. If you don't want to build a waveform data type, set the offset and multiplier properties from the front panek or block diagram. The example called Real Time Chart shows how.
Message 2 of 8
(9,997 Views)
Thanks for response, that was fast 🙂
First, I found 'ignore waveform Timestamp on axes' in the properties, but I can't check or uncheck it. All what I need to do is to plot a graph which has not a constant rate .. and make each 1 unit in the x-axis  indicates one second . I think it should be easy .. I am using the waveform graph indicator. Please, any help.
Flifl, Labview 2009, vista
Message 3 of 8
(9,985 Views)
No, you are using a chart as is clearly shown. As I already mentioned, the default dt is 1 second. And, whether you use a waveform graph or waveform chart, they can only display a  constant rate. Perhaps you want to use an XY Graph. That can display an non-constant x axis.
You could at least post an image of your code. The actual code would be even better.
Message 4 of 8
(9,973 Views)
Thanks again for the fast response .. I'm sorry, you are right, it was a chart ... But, the problem is as you said that the default dt should be 1 second. And as I told you before, I had each 50 units in the x-axis equivilent to approximately 4 seconds and I don't know why. And I need a constant dt equal to 1 second, that's all. So, what could be the problem??
My code is huge relative to the problem.. I will post an image of the waveform-indicator wiring. It's a motion tracker, simply I diffrentiate the x-path to get velocity then to get the acceleration. And each indicator in this shot is a waveform chart and in a while loop. All of them working together, but the problem is in the scale of the time as I mentioned. It's hard to adjust the scaling factor as I don't know each unit is exactly equal what in seconds. So, is there any advice?
Flifl, Labview2009 vista
Message 5 of 8
(9,965 Views)
Well, how fast does your loop iterate? What sort of delay is there. I've already mentioned the example where you use the value of the loop delay to set the x axis timing.
Message 6 of 8
(9,958 Views)
Thanks Dennis, but can you show me the link of that example.. if you mean the real chart example, it was too late version and I got message that labview 2009 cannot open this file.. so is there any other example? And it would be better if the x-axis timing doesn't depend on the loop iteration time, if it could be..
Flifl, Labview2009, vista
Message 7 of 8
(9,924 Views)
Help>Find Examples. Then just go to the search tab and seach for Charts.
Message 8 of 8
(9,919 Views)
