How can I program Labview 6.1 to work with AT-MIO-16
Now I'm working on a project which needs to use an old DAQ board
AT-MIO-16. The only version of Labview I obtained is Ver.6.1, whose
NI-DAQ drive(Ver. 6.9.1) does not support AT-MIO-16. Does anyone has
experience on this?
Thank you for the help!!
(2,645 Views)
1) De-install NI-DAQ 6.9.1
2) Down-load old NI-DAQ (memory says 6.7 maybe).
3) Install old.
Ben
(2,645 Views)
Our non-plug&play AT-MIO boards were last supported under NI-DAQ 6.1, so that's the version of NI-DAQ you need. Ben's right about the process but since LabVIEW 6.1 came out after NI-DAQ 6.1, you need to do a couple extra things to make the DAQ vi's appear in LabVIEW. See the link below.
Using Older NI-DAQ Versions (6.8 or Earlier) with LabVIEW 6.0
(2,645 Views)
