How can I programatically add multiple plot names?
I am running LabVIEW 7.1.1 and I am displaying up to 4 channels of data in a Chart.  I have 4 controls that select which of 6 types of data gets gathered into the 4 channels.  I want to read the string names of the controls and apply them to the plot names.  I have created a property node for the chart, but I only see only one "Plot Name" property.  I tried the attached structure but I get random results rather than the desired ones.
Does anyone have a better way to name multiple plots?
Thanks in advance.
Salty Doug
(3,667 Views)
Use the active plot property.
(Of course you could also do it in a loop with a two-element property node. Wire [i] to active plot and autoindex an aray of names for the plot name)
Message Edited by altenbach on 05-15-2007 01:20 PM
(3,658 Views)
Thanks, I'll give it a try.  🙂
(3,645 Views)
YES!!  That worked great.
Thanks again.
(3,625 Views)
