How can I programmatically connect to a remote front pannel?
I have two Labview applications, running on different PCs. From one of these applications, I want to programmatically select a remote front panel (from the other application), and connect to it.
Actually, I want to programmaticaly do an "Operate & Connect to Remote Panels". I don't want to use an ActiveX container to view an active web browser, which has a pretty bad time response updating the panel.
Hélène.
(3,097 Views)
Look at my answer to same question:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=137&HOID=506500000005000000CEAB0000&HTHREAD=000043982&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
(3,097 Views)
I am looking for the same thing. In debugging, I am loading a remote computer and connecting to its panel through the menu selections. I also want to give this function to some users in the building so that can check on the equipment without going to each one. I am hoping they will give us a property node that so it can be automated in future releases. As of this moment, I do not know how to do the operation under program control. If there is a way, I would be interested in knowing it also.
(3,097 Views)
Can we have an answer to that question from a NI Labview R&D leader? Is the possibility to programmaticaly access to remote panels planed in future LV release?
Hélène.
(3,097 Views)
