How can I programmatically make a printout of an ActiveX container, as a part of a report ??
There is no such functionallity in Repoprt Generation toolkit.. . .  what I can see.. . .(?)
I also tried to walk around the problem, by making the container as a part of a cluster to use ctrl ref. and "Append ctrl image to report.vi". Was not possible. Even not when I tried again, - very very very fast. . .  .
Any suggestions ??
sveinErik
(2,693 Views)
Hi sveinErik,
i am not sure if i understand what you want? First i thought you want to combine a print out of an activex container, for exaple an excel page, with something special from your labview code, but this part
irritate me. So can you please explain what you want to do?
Mike
(2,677 Views)
Sorry for beeng that imprecise/incomplete in my question Mike. Here comes a new try  🙂
My basis is a 3D Surface-control, witch is an activeX container. I want to print out the image of this object as a part of a Word-report. Well, - one solution was to use "Invoke node"/"Get Image" methode on the "3D Surface Control" and  "Draw Flattened Pixmap.vi" on the "Image Data Output" of the invoke node. Then create a "Picture" indicator on the vi's picture-output and  make a "Picture Reference" for the picture, - and then use this "Picture Reference" on "Append Control Image To Report.vi" (Report Generation Tollkit.)
This seems to work properly, but I've got a new challenge : I cant get the resolution I want. The print-out seems to be 8 bit, even thought I ask for 24. Can you advice Mike ? And also, - is there many better ways to solve the "3D Surface control image to Word report"-task ???
Thank you
sveinErik
(svein.erik.westby@simrad.com)
(2,646 Views)
