How can I read X data from one file (.txt), Y data from another file (.txt) and plot a fit of the graph?
I have two files (.txt), one with the X values  and the other (.txt) with the Y values.
Both the files are like this:
34
54
76
89
 and the number of rows is of course the same in both cases.
I want to read them, find a fit for the curve and then have the values of the fit curve disposable for plotting them or for further elaboration.
I have tried using "read from spreadsheet.vi" and the "curve fitting" block but I experienced several problems.
What can I do?
Thank you very much.
Best Regards,
Emanuele Cornagliotti
(3,103 Views)
You would need two separate Read From Spreadsheet functions but if you are using the Curve Fitting Express VI, then you need to convert the x and y data to a dynamic data type. You do this and wire to the Signals and Locations inputs. Instead, you can use the lower level curve fittings functions (i.e. Linear Fit) which accept separate x and y arrays as inputs.
Message Edited by Dennis Knutson on 02-19-2007 09:37 AM
(3,094 Views)
This is actually what I did. I used the curve fitting module (using a spline interpolant) and i converted the data to the dynamic data type:
The problem that I experienced are the following:
1) If I plot the output I always get a graph with time on the X-axis (see picture attachment). In practice the shape of the graph seems correct but the values of the X-axis have nothing to do with the real values I have in the file (Injection levels_Si.txt) and moreover they are labelled as "time". The other file I have attached (Mobility_Sum_Si.txt) is the Y axis.
2) Even if I set in the "read from spreadsheet.vi" the path of those two files I always have to re-input them every time I run my .vi. Instead, I would like to make the program read always from those two files without asking during its execution.
How can I do?
Thank you!!!!!!!
(3,071 Views)
Always regarding point 1). In practice what I get on the X-scale are the progressive indexes of my Y-Values (I have 45 values indeed).
(3,062 Views)
The 'time' and 'Amplitude' on a graph are just labels. Double click on the text to change it. You can also go to the graph's properties and the Scales tab to change the Name.
I apologize - I only showed part of the process. If you use the low level functions (top part in my example) this only returns an x array. To plot the new curve with the original x, just bundle them together and wire to an XY graph. You can also overlay the original XY plot. I haven't used the express function but you can take the output of the express curve fitting and wire that to the Y input of the express XY graph and the x input would be the same that you wired to the locations input.
If you don't want to keep being prompted for file names, just create a constant. On the diagram and on the path input, right click and select 'Create>Constant'. You could also have a front panel control with the paths defined. Right click on a control and select Data Operations>Make Current Value Default. After you do this, you have to save the VI.
(3,040 Views)
