How can I read a TDMS 2.0 file using nilibddc.dll
I have written some Matlab software to read TDMS files into Matlab using the MATLAB TDM example and the nilibddc.dll. However, when I create a TDMS version 2.0 file with Labview 2009 I cannot read it into Matlab as I get the error
ERROR: TDS Exception in Initialize: Tds Error: TdsErrFileVersionTooNew(-2510)
Is this due to the versioning of nilibddc.dll and if so when will this be fixed? I understand that I could convert the TDMS file to version 1.0 however this is impractical and time consuming given the large number of TDMS files that I am dealing with.
(5,127 Views)
At present nilibddc.dll does not support the tdms2.0.
Discussion link
(5,120 Views)
Are there any plans to release a version that does support TDMS 2.0 and if so is an estimated delivery time available?
(5,100 Views)
borert-
Please follow the posts on the link to the forum from muks. This forum will be updated by the Software Engineer currently working on this topic as per his post.
Mike S
NI AE
(5,078 Views)
