How can I read a part of text file between pattern matches in lv?
The text file I am reading is
#HEAD
#ENDHEAD
With this file, how can I read only the part between #HEAD and #ENDHEAD?
JH
(2,899 Views)
Hi advix,
read the whole file and do some mattern patching... If it is a very big file you may try to read in the file in chunks!
(2,883 Views)
Yes I can read the whole file, use pattern match with regular expression. But I couldn't make lv code which was working.
Sample code?
JH
(2,853 Views)
Match Pattern vi has 3 outputs, before pattern, pattern, and after pattern.  Call Match Pattern with the header as the pattern.  Wire "after" output into another Match Pattern, using the footer as the pattern.  The "before" output will be everything between header and footer.
- tbob
Inventor of the WORM Global
(2,849 Views)
