How can I read a special line from a .txt file in BridgeVIEW
I am a beginner of LibVIEW and BridgeVIEW.I record 18 values to a .txt file as one line every 30 minutes.Now i want to know how many lines have been records,and how to read a special line from the file.But in BridgeVIEW only can read lines from the beginning line.How can i do this.
(2,667 Views)
You should use the Spreadsheet string to array function to convert your multi line string to 1D or 2D array containing your records, after that you can easily use the array functions to count or select a specific record (array row).
To pick only a particular line from a multi-line string you should use the Pick Line function that you find in the additional String Functions palette.
(2,667 Views)
