Thank you Gerd. You are right. I figured this out the hard way by counting bytes and randomly trying stuff but its nice to have it spelled out like that. Since then I rewrote the program to get out of the DDT and just use an array.
This lets me load it and use it but it would still be nice to convert it straight into a .mat file from labview.
I am using 300 KS/s for each channel using a 6225 card. The 300 MS/s was a typo. Not much sleeping sometimes.
Currently I just sent out to a binary file then after I take my run I convert it to a text file in the labview vi. It is not graceful but is working.
I'm having trouble reading the vi you sent and many of the others because of "error 9", a different version of labview was used to write it. I'm using 8.0 and I suspect there is a way around this.
Message Edited by cechafin on 05-31-2007 03:59 PM
