How can I read the control value of an array indicator?
Hi all,
I need to read the control value (i.e. index of the first displayed value) of an array indicator... I have looked through all the array property nodes and tried several different ones, but can't find what I need... I am sure I am missing something simple...
Does anyone know how to do this? I have attached an image of the FP to show what I am wanting to read programmatically.
Thanks.
Jack
(916 Views)
Hi Jack,
(908 Views)
Hi PInguX,
Thanks for your reply... I am using LV 2015 SP1 and my property nodes for the U32 MVC array indicator are different to the images you replied with.... I have provided another picture with the options...
Any idea with one to use?
Thanks.
Jack
(885 Views)
Accepted by topic author jcannon
See if you can copy the property node from the VI. VI should be for LabVIEW 2012.
(880 Views)
Thank you, UliB..
It is now working... 😀
(871 Views)
