How can I reference a control containing an array of strings from one project to another?
Hey guys
I have an array of strings containing names in Project A that I want to populate and save in project B. Once populated and saved, I want to be able to unbundle/read the strings in Project A.
I am having difficulty figuring out how to create and populate this. I have tried adding a reference in the control typedef, but I cant seem to use that reference in the other project. Could I please get some help?
Thanks heaps
Message 1 of 8
(2,798 Views)
Please define the words "project", "save", etc.
Why would you even need B in order to read the strings in A?
It typically also help if you could attach your VI instead of pictures.
Message 2 of 8
(2,779 Views)
Project A = projectA.lvproj
Project B = projectB.lvproj
For reasons, I need to keep the names.ctl in project A, and I need to be able to reference the names.ctl in project B, add elements to the array, save (make current values default) and access these in project A again.
Message 3 of 8
(2,755 Views)
This seems like "dangerous" programming to me.  What happens when project A get separated from project B?  It would be best to put the common files in a common library and make a distribution.
Bill
CLD
(Mid-Level minion.)
Message 4 of 8
(2,725 Views)
If you want to communicate between two separate programs/projects, file or TCP/IP is the way.
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 8
(2,721 Views)
Message 6 of 8
(2,678 Views)
And VI Server, which under the hood uses TCP/IP too. It is even possible to use the original code as posted by the OP. The difference will be that you have to configure the "other" project to open a VI server instance on a well known (and unused TCP/IP port) and then using the Open Application node to connect to this VI server instance, then open a reference to the VI in question and from there find the control refnum on the front panel.
The question is if you should do that. It can make sense if you really intend to keep those applications separate but it is extra work, is slower as it needs to transfer potentially large amounts of data (arrays of strings can add up quickly to a lot of data) and only works if the other application is up and running.
Rolf Kalbermatter  My Blog
Message 7 of 8
(2,641 Views)
Another idea: read these "constants" from a text file, that can easily be copied from one project to the other.
Regards, Jens
Kudos are welcome...
Message 8 of 8
(2,636 Views)
