How can I reference an external help file from context sensitive help at the control level?
My goal is to provide context sensitive help for each control displayed on the front panel using a help file created externally. I know that at the VI level I can specify a Help Path; I want the same behaviour for each control inside a VI. I also know about creating a custom control and specifying the Help Path in there, but it doesn't help in this situation, for I have hundreds of controls in my application and I cannot go back and replace each one with a unique .ctl. If I could override each instance of the custom control with unique path data that would do the trick, but that's not how it works.
Is there a way to add the Help Path information to regualr controls?
-euge
ne
(2,693 Views)
This functionality is not yet built into LabVIEW.
About all you can do is cut and paste the help for each control into the description for the control. It is tedius but a finite task.
(2,693 Views)
