How can I repeat the same program automatically with a time-plan?
Hello Everyone,
I have a question here.
I want to start the same program more time, but I would like to define the number of repetitions and time delay between each repetition with a dialog windows.How can I do that?
e.g. I want to repeated the same program for 4 times, first time this program will be started by press "Start", second time it will be started in 10 seconds after the first start, the third time it will be started in 16 seconds after the first start and last time ist in 30 seconds after the first start.
With which node can I do that?
Regart,
Johnny
(3,638 Views)
Hi Johnny,
is it a LabView program? If yes you can create a "vit" of your program and load this dynamically. Load it in a for loop and connect an array to it with the time information. Connect the time value to a wait block. If no use also a for loop but use the "System Exec.vi" instead of the "Open VI Reference".
Mike
(3,637 Views)
yes, it is a LabVIEW programm.
(3,634 Views)
try something like this.
Mike
(3,629 Views)
