How can I reset the following application?
The program below counts every high that is inputed by the button. The problem is that the add function does not reset.
If i start it and klik a couple of times it counts the amount of times I create a new high. But then I stop it adn run it again it continues where it had stopped the last time.
Can somebdy help me out?
(2,669 Views)
You just need to initialize the Feedback Node init terminal on the left side of the loop for your counter. Create a constant outside the loop on the terminal with a value of zero, or what ever you want the starting count to be.
The attached image shows this.
If you do not initialize the Feedback Node, or a Shift Register, it will remember the value that it last contained unless you change it or remove the VI from memory.
Ed
Ed Dickens - Certified LabVIEW Architect - DISTek Integration, Inc. - NI Certified Alliance Partner
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,669 Views)
Thank you very much.
Learned again something today.
Dirk
(2,669 Views)
