There is a option in LV,
"Edit --> Make current value defult"
Every time you reopen your VI, it will set to your custom default value.
There are many ways of doing this.
Another way of doing this is, You can use "sequence structure and property node". Make the property node of your array and choose "value". Then mark it to write. See attach.
When you feel sad, laugh
