How can I retain the most recent values written to an array after the program is closed?
I have an array of counters inside a While loop. These counters keep track of inspection results (number good, bad and so on.) When I close and reopen the program these counters revert back to zero (the default values.) I would like them to retain the last value unless I press a button to zero each.
It seems like this should be pretty straightforward but I can’t figure it out. What am I missing?
(2,465 Views)
Save the values that you want to save to a file and read that file when you open the software to initilize the controls.
Tim
GHSP
(2,463 Views)
I second Tim's suggestion.
The reason is that you want the data to be stored for later retrieval when there is a power outage or if the PC is turned OFF.
Anything that deals with volatile memory just won't do.
(2,447 Views)
