How can I save multiple data coming in from my data string
I am a newbie at labview. I have a scale connected to my RS 232 and made a VI to display the changing scale. I am trying to save the multiple changes as my weight varies but have been only able to save the last value. Is there a simple way to save all the values I see in my VI to a file for later plotting? I have done one before using indexing but the case this time is that I am receiving a character string and not a numeric array. Any examples or advice would be great!!! Thanks
Gerald
(3,553 Views)
Hi Gerald,
What you need to do is write to a file continuously, i.e. after each point you collect.  You can do so by opening a new/existing file, write to it inside your while loop, and close it once you are done collecting and writing data points, i.e. outside the loop.
I believe the following example is a good demonstration of that operation.
Best of luck,
AG
(3,521 Views)
If you don't want to continuously save the data you need to accumulate it into some buffer. (e.g. building an array in a shift register).
You could even simply use a waveform chart, then save the history data as desired.
(3,509 Views)
Thanks for the help guys, I did end up using the waveform chart method......Gerald
(3,492 Views)
