evolution wrote in message news:<506500000008000000CE750000-1042324653000@exchange.ni.com>...
> How can I save my data and the date,the time into the same file when
> I run this VI at different times?
> I use a translation stage for the experiment.For each user in the lab
> the stage position (to start an experiment) is different.I defined one
> end of the stage as zero. I want to save the position , date and time
> of the stage with respect to zero.I want all these in one file, nd
> everytime I run it it should save to the same file, like this:
> 2/12/03 16:04 13567
> 2/13/03 10:15 35678
> So I will track the position from day to day.If naybody helps, I
> appreciate it.Thanks.
I know the function "write to spreadsheet file.vi"
can append the data
to file. You can use the "concatenate strings" to display the date,
time as well as data... Hope this help.
celery
