How can I see the IP-address of the remote panel
Hello all
I use the Remote Panel
How can VI on the Host computers show the IP-address of the Remote computers?
 Regards
Iskanders
(2,742 Views)
Hi Iskander,
I can think of two ways you can find the IP addresses of the Remote computers.  If you are talking about LabVIEW Real-Time, there is an inbuilt VI called "RT Ping Controllers" which will return the IP addresses of your remote systems.  If you are not using LVRT, take a loot at this Discussion Forum.  The other way that I think will work your you is to use system exec or TCP/IP to ping your remote systems and verify their IP addresess.
I hope this helps,
Nadim
Applications Engineering
(2,722 Views)
