How can I set specific bits in a 16-bit integer?
Hello everyone,
as the title says I need to modify or rather to set a specific bit in a string which then is sent to a motor. I need to be sure that my command is correct as I am experiencing troubles with that motor and need to identify if its source.
First of all my strings have to be in the Little Endian order. Then the structure of the string should be the following:
Change Velocity command ‘V’xxCR 056h + one unsigned short (16-bit) integer + 0Dh (Note: Uppercase ‘V’)
Note: The lower 15 bits (Bit 14 through 0) contain the velocity value. The high-order bit (Bit 15) is used to indicate the microstep-to-step resolution: 0 = 10, 1 = 50 uSteps/step.
Until now, I used Flatten To String to convert 32 bit integers into bytes of the correct order. I thought I could use the Join Numbers function, but that only works for at least 8 bit numbers and there is no "1 bit number". I searched for an option to build a a string and set the bits via a Boolean Cluster, but I did not really understand how to transfer this to my problem.
How can I build up the correct 16-bit integer (e.g. set the velocity to "10000" with a resolution of 50 µSteps/step)
I would like to add the "V" and the CR via Concatenate Strings to the 16-bit integer, but other possibilites are also welcome.
I have seens the examples for bit manipulation in C-code, but I wish to do this with LabView as I am not familiar with C,matlab and so on.
Thank you very much for your help!
(7,997 Views)
Accepted by topic author MrKSE
You really need to learn Boolean logic and how to shift bits around.
AND is really good for masking out bits (forcing them to 0) and OR is really good for adding bit values.  Then Logical Shift is used to get the bits in the right places before doing the AND and OR.
NOTE: Rate is an enum with 10 being a value of 0 and 50 being 1.
(7,973 Views)
Thank you very much for your quick answer.
Can I change the representation of velocity to "decimal", even if I use a hexadecimal constant for the AND operator?
Is there a tutorial for this kind of boolean logic? I looked up the functions but for me it only makes sense for single True/False objects. If I connect to U16 with or, will they be compared bitwise and if both bits are 0 the result is 0,otherwise 1, or what does it do?
However, I apologize for my lack of knowledge of Boolean logic and thank you again for your help!
(7,941 Views)
Hi KSE,
Yes. Representation in the display is purely cosmetics, the underlying value doesn't change…
Wikipedia?
Read the help. It clearly says: This function performs bitwise operations on numeric inputs.
(7,933 Views)
When you do bit packing like this a lot, you want to see the hexidecimal representation.  It is much easier to verify the right bits were set/cleared that way.  As GerdW said, the hexidecimal vs decimal is just how the number is displayed; the actual data is the same.
Go to a digital electronics 101 course.  You will learn way more boolean logic than you ever wanted to see.  So I would recommend finding a good digital electronics textbook.
(7,926 Views)
Ah I see, it is emphasized as "Note"..Smiley Happy
I'd like to thank both of you for your fast help. Hopefully this string will solve my problems!
Kind regards,
KSE
(7,922 Views)
