11-12-2008 09:47 AM
Hi Bo,
you can change the value of the clicked element from you intensity graph. Maybe another way is to overlay an image.
Mike
11-12-2008 09:54 AM
Hi Mike,
If I change the value of the intensity graph, do I need to update the whole graph? I only found "value" in the property node to change the element. And, if I overlay the image, the spaces problem is still there, for which it is hard to select pixels. Thank you for your reply.
Bo
11-12-2008 09:56 AM
Hi Bo,
yes you can only read and write all values.
Mike
11-12-2008 09:59 AM
