How can I set up the bridge?
If the supply voltage is 10 V, and the load cell's sensitivity is 2mV/V, then the maximum output signal is 0,002 V
But i get signals 0 V-to 24 V,why?
Thank you.
(3,155 Views)
Do you see at the top right the little drop down menu that says "Scaled Units"?
(3,144 Views)
Yes but the load cells has got mv/V and i set up mV/V. i dont undersant you.
(3,138 Views)
Thiese articles may help to clarify things:
Strain Gauge Configuration Types
What Are NI-DAQmx Custom Scales, and How Do I Use Them?
Best Regards,
T Simon
Certified LabVIEW Developer - Certified TestStand Architect
(3,103 Views)
