How can I show every x-th point of my data measured?
I use "High Speed Data Logger.vi" to measure my data.
While measuring (data acquisition), I want to show every x-th point of the data obtained in real-time if my computer has enough speed to do so.
Could anyone kindly tell me how to do it?
(2,435 Views)
You can use the Index Array VI to get values out of the array from the AI read VI. You could then send that result to a chart. So if you wanted to chart every 10 points you could indexd the 10th point out. Depending on how many points you are reading at a time, you may need index the array at a bunch of different points.
Evan
(2,435 Views)
Thanks, Evan!
I've already found an answer.
Basically, you are correct.
(2,435 Views)
