How can I simplify this?
hello all
My problem is following:
I have a cluster and from the individual fields of the cluster I have to create a string where all values are seperated by a semicolon. How can I simplify that? see picture: the part on the right side.
Thank you all for your help!
(2,855 Views)
Sebastian;
What you are doing is ok (it works!)
An alternative is to use the "Format Into String" VI. Attached is an example
Regards;
Enrique
www.vartortech.com
(2,855 Views)
To expand on your other response, the format to string is the preferred way of formatting a long string such as in your example because it's a lot easier to see what the formatting is doing, and the code takes up a lot less space.
You especially notice the difference when you go to format a long string like an error message or a text report where you are inserting many different values.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,855 Views)
