How can I simultaneously put out two different signals (waveforms: audio left and audio right) with myDAQ ?
I have the same problem, you can't execute the two input in the same time because you have may be DAQmx 6001 or 2..3.
You can choose whic I/O goes with number of channel, but you can't run them simultaniously..
I'm looking for a solution.
S.C
Message 11 of 15
(717 Views)
The User's Manual (https://www.ni.com/docs/en-US/bundle/mydaq-features/resource/373060g.pdf) indicates the analog outs are dual independent DACs and have an audio-output mode.  Is there an audio output option?
Message 12 of 15
(708 Views)
I've solved the problem! Thank you!
I even have two channel selectors now! The problem was, that I did not create two channels in my synth_config.vi. I put my small Fgen test project in the attachments.
If you have anymore tips to improve this little problem, I'd be happy to hear them. (besides removing the local variables and rather directly connecting them)
Message 13 of 15
(696 Views)
Ah so you don't use the DAQ assistant but you use the Daq fonctions and Another VI to do it ? because 'im using two daq so I have to learn how to make a complex programm like yours..
Message 14 of 15
(682 Views)
Yes, basically what I did there was creating a DAQ Assistant which had two output's active and with right mouse click on it and clicking "create code" you will automatically gain the .vi and the rest of the code. You can easily change certain parameters that way.
Message 15 of 15
(670 Views)
