How can I sort a string
I want to sort a string (daycode), I use the daycode to sort my data. Now i want to sort the daycodes, but i do not know how.
Example: the daycode is a10r, so a is the first shift in week (b the second and so on), 10 is the week in year, r is the year.
Now i have a array with daycode-strings and want to sort it to year, week, shift (normaly it is sorted to the first letter).
Someone with a good idea???
Thanks a lot
Marco
(3,934 Views)
Try this vi and see if it is something you might be looking for and if not maybe you could explain a little more about what you want to do.
Joe.
"NOTHING IS EVER EASY"
(3,926 Views)
Hi Marco
Try the attached example.
Good luck
Neil
(3,916 Views)
Joe
I tried the same technique, but I think the week digits become reversed and hence the sort is invalid.
It would have been elegant had it worked. 😉
Neil
(3,912 Views)
Thanks for your fast answer,
I try it.
I write tables in ms access. So the tables are sorted by the first letter.
Example: a10r, b10r, d09r, k09r and so on. So I have 2 tables in week 09 and 2 tables in week 10.
But I want to sort it in LabView like this way: b10r, a10r, k09r, d09r, so that the newest one is the first in the array.
I think, I have to split the string in first letter (shift), than second and third (week), at least the forth (year).
Three steps to sort (year, week, shift), but i do not know how...
Marco
(3,907 Views)
THAT´S IT
Thanks a lot and best regards
Marco
(3,901 Views)
Hi Marco
That can be done quite easily by reversing the array.
See attached.
Good luck
Neil
(3,900 Views)
