How can I start a timed loop with a front panel button?
(2,816 Views)
There are many possibilities. You could for example place it inside an event structure triggered by your button.
(2,812 Views)
You could poll the button with a while loop, then when the button is pressed enter a case structure.  The false state could contain a false constant, wired to the stop condition of the while loop, and in the true case could contain the timed loop and a true constant.
Andy F.
(2,794 Views)
Thanks for the feedback guys. I found that all I have to do is wire the true case of a pushbutton to the timed loop. It works like a charm!
(2,776 Views)
