How can I start multiple Labview build executables in a sequence
I need to start several executables in a certain order with pauses between them.
How is this done.
(2,932 Views)
Why don't you make a new vi which contains a sequence structure and their you put in the program you want to run first (inserting a sub.vi) and then a pause or the second program and so on.
I attached a screenshot by which i think you want to have your program.
If you want to open other executables (for example ms exel and after few seconds open ms word) then its also possible to use the sequence structure.
I hope i understand the question correctly, and this will help you solve your problem
(2,927 Views)
Well the solution which tristan gives will work ,but make sure you put the delay in another sequence and not in the same sequence as he shows for the exact delay between applications.
cheers
vicky
(2,918 Views)
completely true, i guess i'm sleeping 2day 😞
(2,911 Views)
