How can I take the data every 3 s?
What can I do if I would like to take data every 3s when the data are generated continuously?
Can you give me an example?(version6.1)
(2,646 Views)
One simple way would be to check the time in every loop cycle and only acquire data when the time differential reaches 3 seconds. I have attached an example which shows how to do the timing this way and shows where to put your data acquisition. This is a very simplified diagram which is intended only to show you the concept. If this isn't what you need then I would suggest that you post a more detailed description of what you are trying to do.
(2,646 Views)
