How can I tell which controls are customizable?
I have been trying to get a Classic System Check Boxof a different size. I placed one on the front panel and I'm pretty sure it was customizable.  Now when it do the same thing customize is grayed out.  Even when it was customizable I found that I couldn't change it.   I have been trying all sorts of things.  Some controls are editable some are not.  Some you can import pictures from the clipboard some you can't.
Is there a good tutorial that tells you all this stuff?
Is there a list which says which ones can be customized?
(2,927 Views)
  1. Works fine for me. Are you sure you've selected the entire control? Left click and draw a box around it. Then Edit>>Customize control.
Hope this helps.
Oops I meant left click.
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,924 Views)
The classic boolean palette has two checkboxes:
(1) A sytem checkbox in row 5 and (2) a checkbox in row three all the way to the right. Only #2 (the one with the X) can be customized.
(2,917 Views)
Thanks for your reply
I placed a fresh Classic>Boolean>System Checkbox and I the customize control was grayed out.
Shutting down LabVIEW and restarting I find the same control now customizable.  However in the control editor the spanner (edit mode) tool is grayed out.
I have LabVIEW 2011 Full Development System
(2,916 Views)
I still can't explain the change from not customizable to customizable
However part of my confusion was that I saw the "Import picture from clipboard" was grayed out on some of the controls I was trying to edit.  Silly me, I didn't have anything in the clipboard for it to import 😞
Thanks for the replies
(2,902 Views)
