How can I test the I/O in my NI USB-6009?
I want to test all the Inputs and Outputs of a DAQ NI USB-6009 using LabVIEW. This is to check if all the I/O works correctly.
Actually i do this ussing a voltimeter but its take a lots of time and i want to know if i can do this more automatically ussing LabVIEW.
(3,104 Views)
Have you tried just looping back the I/O?
(3,097 Views)
nope im new in LabVew and i was thinking to use structures,
(3,093 Views)
I don't understand what structure you could use. To confirm that a digital line could output a one or zero, to fully test the path you would need to connect it to a digital line configured as an input. Some DAQ devices have internal loopbacks. I don't know if the 6009 has that capability. You can check the manual. Otherwise, you would need external wiring.
(3,090 Views)
ok Thanks men!
(3,085 Views)
