05-18-2006 09:39 AM
05-19-2006 04:18 PM
Hi Chad,
Timestamp information is built into the waveform data type, so you should be getting this information automatically from the DAQmx Read. Could you be a little more clear about what exactly is going wrong? The error message that you mentioned -- is it coming from the DAQmx driver, LabVIEW, or Windows? In some cases, CPU usage of 100% with DAQmx is perfectly normal (as explained here), so that doesn't necessarily tell us much. What would be more informative would be the actual contents and context of any error messages that you are receiving.
Kind Regards,
