How can I turn off all LEDs on breadboard through DAQ when I click the STOP button?
Dear NI family,
I am new with LabVIEW. I am now designing a program to run the LEDs in sequence, however, when I push the STOP button, always there will be one LED is on.
What should I do if I hope to turn off all the LEDs once I push the STOP button?
The code is in the attachment.
Thanks a lot!
Best,
Jason
(2,971 Views)
Hi leo,
when you want to turn off all LEDs before your program exits you need to turn them off…
Simple solution: turn them off after exiting the loop!
On your VI:
You should open/start a DAQmx task somewhere and you should stop/clear the task - as is explained in all those example VIs coming with LabVIEW. Did you examine them?
(2,958 Views)
Hi GerdW,
Could you please spare some time to check my vi? I am not sure how to change it to deal with the problem.
Thanks!
Best,
Jason
(2,952 Views)
Hi leo,
After setting those DOs in the loop you need to set them to 4×FALSE after the loop to turn all LEDs off.
This is all that very basic THINK DATAFLOW!
Everything in a VI is in a certain order: all you need to do is set the DOs to FALSE in the right place!
Real life example:
You want your house locked when you leave. Before leaving you are (un)locking several doors "randomly". But when leaving you lock all the doors - and go.
Now replace "house" by "VI", "lock" by "turn off", "doors" by "LEDs", and "go" with "exit"…
(2,941 Views)
