How can I unintsall labview 2010 ? I install labview 2010 first.
I install labview 2010 at first.
I install labview 2010sp1 after  a period time.
I would like to remove labview 2010 and then keep 2010sp1.
How can I do ?
I can't found that national instrument item of add/remove software in the control panel.
Have extra remove  tool help to remove them ?
I would like to keep one to save disk space.
Longmild
(2,581 Views)
Hi longmild,
                Go through these links:-
https://forums.ni.com/t5/LabVIEW/how-to-uninstall-LabView-when-it-s-not-in-Add-Remove-list/td-p/6186...
https://www.ni.com/docs/en-US/bundle/labview/page/uninstalling-labview-built-installers.html
https://forums.ni.com/t5/LabVIEW/remove-labview-2009-without-using-add-remove-program/td-p/1398624
Thanks as kudos only:)
(2,580 Views)
The 2010SP1 overwrites the 2010.  So there's no need to uninstall.
(2,551 Views)
