How can I update the table when new values come
Hello all!
I am new to Labview and I need your help! I currently meet two problems in Labview.
1. The first problem is the table. I use 'build table' vi. in my system and I have a excel table in the front panel. This table is to show the data I measured. However, it seems the table is updating according to the current time. But what I really want is that the table only records the new values. How can I do with that?
2. I have two measurement values from two channels. I will use this two values to do some calculation. For the calculation, I employ a simple Formula node. The problem I am facing to is that the result value will change when anyone of  input values changes. How can I do if the operation can wait until the two input values change?
Thank you very much
Best Regards
Daisy
(2,378 Views)
This board is for Version Conversion ONLY.
Why don't you post it in the LabVIEW board?
http://forums.ni.com/t5/LabVIEW/bd-p/170
Mondoni
(2,372 Views)
