02-07-2007 11:55 PM
02-08-2007 01:41 PM
03-07-2007 04:27 AM
sorry for not replying for a long time.
i had found a way on how to energize the relay using BNC. i used a simple circuit with a transistor and a power suply to drive the relay. i connect the output of the BNC to the base of the transistor and the transistor become a switch for the relay. i had never try do as you suggest but i think it might be working. the problem is that i need to use every output for different relays. anyway, thanks to Conseils for giving your suggestion.
