How can I use DAQmx to route analog output 0 to an analog input?
I'm using an E series DAQ card - PCI-MIO-16XE-10.  I'm converting my Traditional DAQ (Legacy) software over to DAQmx.
Previously I've used analog inputs 21230 and 21240 to route my analog outputs to the analog to digital converter (see article: http://digital.ni.com/public.nsf/allkb/6C77B1884F5BBEE8862569E3005BE30E), and it has always worked fine.  Now that I'm using DAQmx, however, I can't seem to read off of channels 21230 and 21240.  The DAQmx vi that I wrote can read off of other analog input channels (ai0, ai1, etc), but not off ai21230 or ai21240.  Does anyone know how to fix this?
Steve
(2,662 Views)
I've just discovered the Internal AI Channels, and can now configure "Dev1/_ao0_vs_aognd" and "Dev1/_ao1_vs_aognd" to do what I need.  Problem solved!!
Steve
(2,649 Views)
