Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How can I use Labview VIs to recall saved setups on my Tektronix TDS540c?
Jeff.Jin
Member
02-06-2003
06:55 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want a LabView5.1 VI to recall saved setups on TDS540c CRO. I have got a driver set(tktds5xx.llb) for the CRO, but there is no such vI for the recall.
I'am using GPIB interface and windows98.
0
Kudos
Message
1
of 2
(2,702 Views)
Reply
Re: How can I use Labview VIs to recall saved setups on my Tektronix TDS540c?
Al_S
Active Participant
02-07-2003
09:37 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
The TDS540C had a RECALL:SETUP command. You can download the programmers manual (document 70987600.PDF) from
www.tek.com
0
Kudos
Message
2
of 2
(2,702 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
