How can I use Labview to control ST Micro ST-Link Software?
Hi-
I am putting together an automated bench to allow a user to program ST Micro
devices on a PC board and I was wondering if there is a way to  control the ST Micro
ST-Link software with Labview to make this task automated and easier for the user.
I have searched online looking for some examples or a whitepaper on this but have not
found anything usefule yet. Any links or suggestions are appreciated.
thanks
(5,211 Views)
See if they have a command line option. I have used this with other programmers and it works well. Simple build a command line in LabVIEW and send if with the system exec command. Check the return code to see if it worked.  If none available, try AutoIt to automate the keystrokes. I have used that also and it can work well.
(5,177 Views)
Hi guys,
Any example to control ST Micro ST-Link Software?
(4,096 Views)
Hey srh1985,
This thread has been dead for 2 years. It's pretty unlikely that anybody is going to see this. You'd probably be more successful opening a new forum thread
NickelsAndDimes
Product Support Engineer - sbRIO
(4,079 Views)
