How can I use Visual Basic code with labview 6i?
I would like to know how to incorporate visual basic code into LabVIEW.
(2,716 Views)
kmiller;
You can create a dll with Visual Basic and call it from LabVIEW.
The following example may be of help:
Passing Arrays from a Visual Basic DLL to LabVIEW
You can also use ActiveX. Check the following example:
Passing Data between LabVIEW and Visual Basic Using the ActiveX Server
Regards;
Enrique
www.visecurity.com
www.vartortech.com
(2,716 Views)
