How can I use a COM object that does not have a type library?
I've created a com server in python for which I do not have a type library. I am able to call functions for this application in Python, TCL, I'm sure VB, etc. without the type library.
Must I have a type library registered to use this COM object with Labview? I was hoping I could simply supply the name to the refnum (or the GUID) then call functions by passings strings to the invoke node. This does not seem to be possible - am I missing something?
In the event that I cannot use a com server without a type library. Any recommendataions on how to create one? I'm wondering if I can use the same GUID and create a shell in LabWindows which generates the IDL/TBD file I need for Labview to see my
com server.
Any help is greatly appreciated.
73,
Timothy
(2,836 Views)
> IDL/TBD file I need for Labview to see my com ser
ver.
There was a discussion on LAVA about Python and LabVIEW with
a link to an example. I hope this helps:
http://forums.lavausergroup.org/index.php?showtopic=173
Michael Aivaliotis
http://mmwis.com
http://niweekblog.com
Michael Aivaliotis
VI Shots LLC
(2,836 Views)
Thanks for the info, however their example is labview server and python client. I'm going the other way. It's good to know about LabPython though...
As of now, it seems to be there is no way to use a COM object without a type library from inside LabView.
73,
Timothy
(2,836 Views)
> LabPython though...
Yes that is true. LabVIEW needs that to configure the Property and
Methode Nodes correctly. Otherwise it would need to have a special
Property and Method Node with a configuration dialog similar to the Call
Library Node, but a LOT more complicated. Not sure many people could
make use of that, and it would be a very tiring experience trying to get
things setup in that way, by going through the edit, test, and crash
cycle over and over again.
Rolf Kalberm
atter
Rolf Kalbermatter  My Blog
(2,836 Views)
