While a VI is running displaying data on the screen, a second Windows program should control the timing of a read (file writing) of the VI. The Windows program has the ability to generate DOS command lines at specified times. I would like to create a while loop to control file generation of the VI but am not sure how to interface the DOS generated command with the VI
