How can I use a control in different TAB Control
Hello LabVIEW Enthusiast,
I'm using Tab control (multiple) and there are some controls over there. What I'm trying to do is:
The same control will be available in the different tab and if in one place control value changes another tab's control value will be updated with the same value.
For easy demonstration I'm giving an example:
Here, Firstly Input 1 should be available in the page 2 tab, and then if I change the Input 1 value from page 2, page 1 Input 1 value will also change. So Input 1 control value should be the same on page 1 and page 2 tab.
Snipped also attached if you need to change in this example.
Appreciate your kind help.
- Reduanul
Message 1 of 8
(3,068 Views)
Accepted by topic author REDUANUL
Hi Reduanul,
When the control should be visible on all tabs then you need to place that control over the tab container, but not inside the tab container!
  1. Move the control outside the tab using the mouse.
  2. Then select the control and move it using the arrow keys over the tab container! (Maybe change the z order using the foreground/background/grouping options in the menu to get to control in front of the tab container!
  3. Now you are done: the control will be visible on all tabs… (The border visible at edit time will vanish at runtime.)
You didn't attach a snippet, but an ordinary image. This is quite a difference in LabVIEW! (Please read the LabVIEW help for snippets!)
Message 2 of 8
(3,038 Views)
Thanks, GerdW it's working 🙂
Now is it possible to get rid of the black border color at edit time?
Then can I make control visibility on selective tabs instead of all? (e.g only on tabs 1 and 2 whereas I've 3 tabs and on tab 3 it will not be visible)
Like this:
Last time as I said I uploaded a snippet that will work if you drag that image to the block diagram. I've checked it worked 🙂
However, this one is the updated snippet for the above case.
- Reduanul
Message 3 of 8
(3,012 Views)
Hi Reduanul,
The black border will always be visible at edit time.
To control visibility programmatically you can use property nodes for that FP element…
I'm sorry, I didn't check the attachment. I just saw the image in the message text.
On your snippet: why is there no label at the tab terminal?
Message 4 of 8
(3,007 Views)
Hello GerdW,
It will be also possible to remove the black border invisible at edit time (I tried and it works). For this you just need to put the control on a flat box like this:
Thanks for your awesome help 🙂
Message 5 of 8
(2,998 Views)
Hi Reduanul,
What's the point to put more stuff on the frontpanel than needed?
Your users will never see the black border as they only see the frontpanel at runtime. That border is just a visual reminder to you (as the programmer) that this control hovers over the tab container…
Message 6 of 8
(2,993 Views)
Hello GerdW,
Yes, that true but I did for looking visually clean.
Another thing I forgot to ask is there any way to do this? :
When I exit the program then Input Button 1 will be visible on Page 1 and on Page 2 it will remain as invisible?
I tried with the property node but did not work. In all tabs, it remains either visible or invisible.
- Reduanul
Message 7 of 8
(2,986 Views)
Hi Reduanul,
When the VI has stopped then the code in the block diagram cannot react to user actions anymore: the last visibility setting will stay active until you run the VI again…
As I said before: your users will never see the frontpanel at edit time - so what's the problem?
Message 8 of 8
(2,953 Views)
