How can I use labview to FT images from a CCD realtime?
I want to use labview to process my images realtime and display the output. I am using a Basler CCD camera to capture the images. I do not know where to begin, whether I need toolboxes or different hardware. The Basler cameras use firewire and are programable in C++ but I do not know this language. Can I get labview to retrieve the output from this camera and perform a Fourier transform on it frame by frame and display the results? Please advise.
Thanks.
(3,303 Views)
AJ17,
Yes you can do this in LabVIEW. You will need to ensure your camera is firstly supported:
http://sine.ni.com/apps/we/nipc.specs?action=search&asid=1102
Then, you will need to purchase NI-Vision which is the vision library that has all the vision processing functions within it. I would advise purchasing the Vision development module.
You may also need a frame grabber but look at the camera advisor ni.com/advisors to find more information about the correct one.
NI-IMAQ 1394 and NI-IMAQ for USB is also available.
Hope this helps.
Kind Regards
Steven Bird
(3,279 Views)
Thanks Steven! We already have a group licence for the Vision software but do I have to buy the NI-IMAQ licence seperately? Is the NI-IMAQ for using in replacement of a frame grabber?
Anne Marie
(3,276 Views)
Anna,
NI-IMAQ is a free driver likewise for NI-IMAQ for USB. However the firewire drive you may have to buy unless its part of the academic bundle.
NI-IMAQ supports all NI frame grabbers.
Hope this helps
Kind Regards
Steven Bird
(3,272 Views)
Thanks, yes that helps. It seems to be working! However I do have one more question... Is there a function for doing a 2D FFT? And where would I find it? We have labview 7.1
(3,266 Views)
AJ17, NI-Vision only has the IMAQ FFT for an IMAGE. The image format is based on a 2D array of values. However I don't believe this is algorithm in which you require?
If its not I believe you could create this yourself, make a dll and then call it within LabVIEW.
Kind Regards
Steven Bird
(3,257 Views)
I posted this one in another similar thread.
Randall Pursley
(3,254 Views)
